98 camry won't start when cold
Old Aug 17, 2008 | 10:43 AM
ericg's Avatar
Default 98 camry won't start when cold
My daughter has a 98 4 cyl Camry with 70k miles. recently, when she attempts to start the car after sitting overnight, she turns the key to the start position but nothing happens. The motor does not turn over, there is no attempt to start. After turning the key to the off position and back to start, it will start on the third or fourth attempt. Once the car is warm, it will start all day with no problem.The battery was replaced less than a month ago. Can anyone think of anything that could cause this such as the starter solenoid? In advance, thanks for any help.
Old Aug 17, 2008 | 01:14 PM
pedro's Avatar
Default RE: 98 camry won't start when cold
First thing I would do is make sure all your battery and starter connections are clean and tight. If the battery was replaced but the terminals were not cleaned or tightened then that may be the problem. Also remove and clean the terminal connections at the starter, but disconnect the battery first. This is something you can do yourself with a wire brush. There could be a short in the starter or even a faulty ignition switch so if cleaning does not correct then you'll have to check further.
foxyroxy111298
Apr 19, 2012 10:15 PM
carNewbie
Jan 31, 2008 06:43 PM
90Camry
Oct 24, 2007 11:26 AM
briansturgeon
Oct 26, 2006 09:44 AM
