98 Camry XLE V-6 traction control problem
Old Apr 14, 2009 | 01:33 AM
graphicsguy's Avatar
Default 98 Camry XLE V-6 traction control problem
Hello, I am new to your site and trying to get an answer to why my Camry traction control light keeps coming on even after clearing codes, It only does it if the car spins one of the front wheels when traction control is on, once it does this the light will stay on untill reset by obd2 scanner.
Wheel speed sensors?
Old Apr 14, 2009 | 08:10 AM
Get any trouble codes readout.
Determine if the engine compartment has a small plastic box labeled "Diagnostic" on the passenger or drivers shock tower mount.
If so use a section of wire to jump the Tc and E1 terninals inside the box then turn ign switch on.
If any codes are stored the TRAC and or ABS dash lights will flash them out.one numerial at a time then repeat. 1 flash, pause, 1 flash = code 11, etc.
A code reader may also be able to read them out.
urox
Feb 16, 2014 09:01 AM
al13n1nv8d3r
Oct 19, 2011 07:27 PM
Sizemo81
Dec 27, 2009 08:09 AM
KaiserSolara
Sep 2, 2009 07:28 PM
carlkra
Feb 1, 2009 04:58 PM
