99 Camry crank but won't start
Help!! I drive a 99 Camry le and t wont start. Recently had to change the fuel pump. But now it won't start. I don't now hats wrong. Can anyone plz help point me n the right direction? I appreciate it.
It is the 2.2 ltr 4 cylynder
i drove it one night to the store and when I try to leave for work in the morning it went into reverse moved about five feet and died. while I was looking around trying to figure out what was going on I realize the fuel pump is not turning on when I turn the key on so I check out the fuses and nothing seems bad or blown then I noticed the fuel pump is not coming on so I replaced the fuel pump but the engine still seems starved for fuel when I try to start it. Oh by the way I probably should have mentioned this before the Camry has over three hundred and thirty-five thousand miles on it. also when I changed the spark plugs I noticed that there was engine oil on them I've been told that's a blown head gasket hopefully if that's what it is is not a major expensive fixed and sees all their heads right on top because I please get some direction or insight on what to do with the Camry thank you in advance
