Car won't start
PLEASE HELP!!!!!!!!! I have a 1996 Camry. It has 218,000 miles on it. Ok, over the last month, we have had some work done to our car. It all started when the timing belt went out. A mechanic put a timing belt kit on, replaced the water pump, and fixed the exhaust leak we had. A week later we had to replace the air conditioner compressor. So now the car is not wanting to start. It would turn over but wouldn't crank. So we replaced the fuel pump. It worked fine for 3 days, but now it won't crank again. It turns over but doesn't start. The fuel pump is pumping fuel. Also, I don't know if this will help or not but before all of this started the gas hand could always be read without the car being on. Well now it is bottomed out below empty even when turning the key over. It has a half a tank of gas though. What could our problem be??
Honestly it's hard to know without testing things however I did the coil on my 85 Camry and it only lasted about a week. It is possible you got a bad part or something else is still wrong. It is possible to be getting fuel but not enough to start your car so I wouldn't rule that out unroll you hook a pressure guage up. Or could be numerous amounts of sensors.
jungling
Sep 20, 2011 09:07 PM
