air temperature sensor
Old Jun 27, 2010 | 09:36 PM
brianjrealtor's Avatar
Default air temperature sensor
1993 camry LE 4cyl.
what does this gizmo do that is located in the air filter cover?
what symtoms if it goes bad or is aged??
Old Jun 28, 2010 | 10:15 AM
The sensor tells the computer what temp the intake air is to the engine. The computer uses this info to set the air/fuel ratio.
If the sensor fails the computer will set default mode temp of 68F.
If the air temps are higher or lower then this default setting the mixture will not be correct.
Craig Lance
May 6, 2014 02:10 PM
Debunker
Dec 5, 2013 03:02 PM
DaveInDenver
Mar 4, 2012 01:16 PM
doomfarmer
Jun 10, 2008 08:31 PM
fobber
Jun 18, 2007 04:03 PM
