Bad alternators
Old Oct 29, 2019 | 08:46 AM
Shon's Avatar
Default Bad alternators
I have a 09 camary this is the 3rd alternator this year has anybody else had this issue?
Old Oct 29, 2019 | 10:00 AM
Are the alternators new, no name rebuilt, name brand and how do they fail?
Is the car electrical system stock, has large stereo amp, etc?
How is the battery, battery cables and connections, alternator connections, wiring, etc?
Old Oct 29, 2019 | 02:05 PM
Shon's Avatar
It's all stock the alternator have been master craft remain except the 1st one that was oem the wires and connections seem to be fine and the battery is fairly new
Old Oct 30, 2019 | 05:25 PM
Are you driving long enough to recharge the battery?
Does the car have any large amplifier for stereo or installed high amp lights?
When driving with the head lights and heater blower on, do the lights dim at idle?
Alternators don't like bad wiring, ground problems, intermediate connections in wiring and generating too much power. If somehow the battery gets disconnected from the alternator even momentary (bad connection) the alternator can be damaged.
Make sure the battery is good and doesn't have an internal short.
Check any battery connections including negative battery cable to chassis ground. Make sure there is a ground strap between the engine and chassis.
Its possible to get a bad rebuilt alternator out of the box.
Old Oct 30, 2019 | 08:39 PM
Shon's Avatar
Thanks I will check the wiring out and get Batt.tested
Old Oct 31, 2019 | 10:58 AM
Its possible for an alternators electrical system to partially fail as in one diode fail. The result is less amp output when then strains the alternator more. However the alternator should not be damaging diodes until there is a problem.
Brirot
Mar 2, 2020 02:34 PM
Valton
Oct 2, 2010 09:38 AM
nickm20
Mar 16, 2010 05:34 PM
diver1972
Apr 17, 2008 04:59 PM
2fast
May 30, 2007 08:13 PM
