brake problem
Old Jun 3, 2016 | 02:59 PM
tcount's Avatar
Default brake problem
2007 camry xle front brakes shimmy real bad when stopping, replaced rotors and pads but still same problem. need help
Old Jun 3, 2016 | 03:15 PM
wdc123's Avatar
Check suspension: Tires off ground: Grab tires and pull back and forth. Place a crowbar under tire and try to move up. You are checking outer tie rods and ball joints.
Old Jun 5, 2016 | 06:26 PM
Did you clean the rotors of any protective oil?
When you replaced the pads was the caliper free to slide in/out on the pins?
Any vibration when not braking?
Old Jun 6, 2016 | 12:05 AM
Are the tires worn?
Old Jun 6, 2016 | 10:30 AM
tcount's Avatar
tires good had them balanced and rotated before brake job.
all calipers sliding on pins, put brake grease on all moving parts and anti seize on all pins, no shaking when brakes not applied.
Old Jun 6, 2016 | 09:59 PM
camri's Avatar
What brand of rotors and brake pads did you use? That could also be the culprit sometimes.
juarez1980
Nov 22, 2017 08:18 PM
1989_Camry
Dec 27, 2015 09:21 PM
CamryLastFoureverNever
Mar 16, 2015 07:57 PM
rapala13
Oct 3, 2013 04:49 PM
daddyd5150
Nov 10, 2006 08:51 PM
