car shutting off problem
Old Mar 5, 2009 | 11:45 PM
CKOFER's Avatar
Default car shutting off problem
Hi I have a 99 Toyota Camry and when I drive it its okay but when I come to a stop or light it starts to want to turn off, the RPM meter starts to go down to zero and it turns off, I have to put it on Neutral and I have to step on the accelerator so it wont turn off, ANY IDEA?
Old Mar 6, 2009 | 11:01 AM
V6 or 4 cylinder.
Do a Google search and read up on cleaning the Idle Air Control Valve (IAC) for your engine model. The valve controls idle speed. It is attached to the throttle body.
V6 = 1MZ-FE
4 Cyl = 5S-FE
Old Mar 6, 2009 | 01:10 PM
CKOFER's Avatar
its a 4 cylinder., i think i may have found the solution though, one of the spark plugs is loose, i presed down on it and the problem went away for now.. thanks, ill check IAC though just to be sure
Old Mar 7, 2009 | 10:52 AM
Sounds like you solved the problem.
erod
9
Aug 7, 2014 12:41 AM
Camry84
Nov 16, 2011 07:33 AM
