Center rear light
Old Apr 9, 2007 | 09:37 AM
2006cam's Avatar
Default Center rear light
Hello I own a 2006 Camry. Recently I had the front windshield replaced due to rock hitting windshield. Today on my way into work, I noticed that the center tail light (the one in the rear at the top, not brake lights or rear lights) doesn't seem to turn off. Could this be related to the windshield repair or something else? Is there an easy way to remedy this situation? I am pretty much an idiot when it comes to stuff like this and apologize if this is a stupid questions. Thanks for any replies.
Old Apr 9, 2007 | 01:53 PM
nodrogkam's Avatar
Default RE: Center rear light
welcome to forums
u say not the rear brake lights or the rear lights, but you say center tail light that is at the rear on the top which would have to be the highmount brake light, right?
Its red and usually turns on when you brake?
The only reason i can think of for it to stay on, even when the car is off and locked is wires have been crossed or there is a relay malfunction. Electronic problems are terrible. You can take it out and follow the wires and see if there are issues. For the time being, you can pull out the bulb (careful hot), or the fuse to deactivate it.
Old Apr 9, 2007 | 02:26 PM
2006cam's Avatar
Thanks for the response. That's sort of what I figured, just wondered whether it had anything to do with the front windshield being replaced since it hadn't been a problem up until then. I will see if any further poking around yields results, otherwise, I'll just pull the fuse or bulb for now.
Old Apr 10, 2007 | 01:32 PM
nodrogkam's Avatar
shouldnt affect it unless they fiddled with more stuff.
jbwood89
Oct 11, 2009 09:36 PM
KillaCam86
Nov 4, 2007 01:56 AM
slippin2
Oct 2, 2007 09:50 PM
donlaziejoker3
Mar 29, 2007 01:40 AM
waconightrider
Aug 11, 2006 12:46 PM
