Center Console wont light
Old Oct 25, 2007 | 12:32 AM
KillaCam86's Avatar
Default Center Console wont light
i have a 98 camry and my center console wont light. i think it is just a loose connection b cause when it went out one day i just tapped it a bit and it came on. i dont know how 2 access it does any body know what i have to take apart first to get to it?
Old Oct 31, 2007 | 12:54 PM
boogz's Avatar
Default RE: Center Console wont light
My center console does the same thing. a little tap and it comes back on. I'm not too sure about a 98', but in my 01' you can just basically rip off the blk piecees to the center console to get to the back of the AC controls/radio. Unscrew the screws that hold down the ac/radio and check if there is a loose connection, or just replace the bulbs.
Old Oct 31, 2007 | 02:01 PM
KillaCam86's Avatar
finally some help thanks immma try it to day what are the bulb size ? can you cahnge the colors
Old Oct 31, 2007 | 02:06 PM
KillaCam86's Avatar
ohh it not the a/c panel it where you shift into PRND21 that wont light how do i get access to it
Old Nov 1, 2007 | 03:51 PM
boogz's Avatar
In my car all you have to do is take a flat head screw driver and pry open the plastic piece that holds down the "PRND21" and after that i believe there are screws to unscrew to actually get to where the bulbs are.
Old Nov 4, 2007 | 01:56 AM
shebal's Avatar
i agree with boogz, its probably a loose connection. happened to my 2002.
ferrarifan
Jan 2, 2012 03:13 PM
markscam2u
Sep 11, 2009 04:42 PM
ARGuck
Jul 21, 2008 02:08 PM
hoopz111
Mar 14, 2008 12:13 PM
waconightrider
Aug 11, 2006 12:46 PM
