Check engine light
Old Jan 26, 2008 | 11:58 AM
Langa's Avatar
Default Check engine light
Hello everybody, I am new around here and have a little problem with my 2001 Toyota Camry CE standard.
Everything seems and runs fine but on chilly mornings the "check engine" light goes off you all know what I mean lights ip and stays like that if I do not do anything, took the car several times to AutoZone and they say is the gas tank cap, bought a new one, happens the same thing it seems to be fine in a warm environment but as soon as turns "cold" around here (Houston, TX) baaam!!!!! light is on.
What do I do?
Langa
Old Jan 26, 2008 | 01:27 PM
pedro's Avatar
Default RE: Check engine light
Code?
Old Jan 27, 2008 | 02:13 PM
Toyota Technician's Avatar
if auto zone told u it was a gas cap then more then likely they have a p0441 p0446 code and yes a loose gas cap or worn seal can cause this but 75% of the time it is the tank bypass vsv mouted on the side of the charcoal canister.
sconley
Mar 2, 2012 09:33 AM
hardyrxp
Mar 31, 2010 02:10 AM
Robster
Jan 5, 2009 06:35 PM
Slomo_01
Jan 22, 2008 09:47 AM
