Dealership no help with brake noise
Old May 5, 2014 | 04:51 PM
mark garrett's Avatar
Default Dealership no help with brake noise
pad shifting noise, any way to stop this. In reverse only. click click.
Old May 5, 2014 | 11:23 PM
Did you buy this car from them? Did they even look at the car?
What year and trim Camry do you have? Disc brakes all around or drum in the rear?
Set and release the parking brake a couple of times, sometimes they get hung up from not being used. This happened on mine but has gone away because I use the parking brake enough now. Maybe the problem???
Old May 6, 2014 | 09:54 AM
yes, yes, 2012 le, yes drum in rear. Noise seems to be in front. Thanks for the tip on parking brake-will try it.
Old May 7, 2014 | 12:00 AM
If the noise is in the front, then the parking brake won't help. If you're not mechanically inclined, try a different shop.
CamryLastFoureverNever
Mar 16, 2015 07:57 PM
Shawn98408
Oct 18, 2010 08:58 PM
sshoaib
Mar 2, 2010 05:56 PM
janet
Jul 11, 2007 12:56 AM
