Does the motor need to be jacked up to get the cam seal in?
Old Oct 21, 2015 | 07:23 PM
gnx547's Avatar
Default Does the motor need to be jacked up to get the cam seal in?
97 Camry 3.0 V6, installing the cam seal by the alternator is easy but the cam seal near the strut tower is impossible to get in. There is not enough room back there to hammer it in and I barely can tap the hammer on the socket. The light tapping is not enough to get the seal in. Does the motor need to be jacked up to get the seal in?
Old Oct 23, 2015 | 03:11 AM
dirty hands's Avatar
had to look at the picture for quite some time
looks almost impossible to hit the seal straight on
a shallower socket or a correct outer and inner size piece of pipe to hit the seal in
there is a special toyota workshop tool
09223–15030 Oil Seal & Bearing Re placer page 4 of the engine pdf below
you probably already have this information
the 1MZ–FE engine ....v6 pdf ......599 pages
http://www.turboninjas.com/camry/eg2.pdf
looks like the 1997 -2002 camry changes were cosmetic and less mechanical
source contains 4 cyl and V6 engines and other bits
Toyota Official 1994 (1992-1996) Mk3 Camry Repair Manual
gnx547
Oct 27, 2015 05:09 PM
gte
Aug 15, 2009 03:01 PM
toyorotor
Jul 10, 2009 07:27 AM
Indolent
Jan 17, 2007 06:19 PM
Indolent
Jan 17, 2007 06:18 PM
