97 Camry misfire
Old Dec 20, 2011 | 09:33 PM
jwcamry46's Avatar
Default 97 Camry misfire
I have a 97 Camry with the 4 cyl. 2.2L about 120k miles, that misfires with codes P0300 random, and P0301, and P0304. This just occurred 2 days ago while driving.
I put new plugs and wires in about a year ago, or 10k miles ago. I saw in a different thread about rotten egg smell and think I might have smelled it when it happened, so wondering if a bad catalytic converter could be problem. It misfires in idle and drive with reduced performance. Possibly coils could be bad. I would appreciate help. I filled the gas tank and put in seafoam like product today. Thanks
Old Dec 21, 2011 | 11:21 AM
Rotten egg smell can be the converter but would not replace it unless positive the converter was bad.
If the ign system uses 2 coils swap coil position. If the CEL comes on check if the codes are now P0302, P0304 following what is be a bad coil.
Old Dec 27, 2011 | 07:27 PM
jwcamry46's Avatar
Thanks Very much Joey, you're awesome. I put a new coil in for cyl's 1+4 and it ran good but not 100% because I may have damaged the wires getting them off the coil. So I put in new wires and it runs great, (code went away). But the Coil for cyl's 2+3 isn't bolted to the block, I was having a difficult time trying to thread the bolt through the block and coil.
Old Dec 27, 2011 | 09:05 PM
full house's Avatar
wow! congrats... just wanna know, how much did you spend on those coils?
Old Dec 28, 2011 | 10:26 AM
Great job, thanks for posting back with the fix.
Old Dec 28, 2011 | 10:59 AM
jwcamry46's Avatar
It was $67 with tax for one, the other is still good. It leaks oil, have any info where to start, or a thread on that? Thanks very much
Old Dec 28, 2011 | 11:19 AM
Leakage areas have been covered in other posts.
Determine if the oil is engine or trans fluid.
Typical engine areas are:
Firewall side of valve cover gasket
From under the timing belt cover. If so check cam/crank and oil pump seals.
Sometimes the plug in the head where the distributor used to be leaks.
Old Jan 9, 2012 | 04:50 PM
jwcamry46's Avatar
Default more codes
Not very long after the engine light went off, it came back on. Its been a couple of weeks and seems to be running well. The codes are po300 random, po301 cyl1, po304 cyl4, and po420 (bank1)-(catalyst efficiency below threshold). Could this mean bad catalytic converter, or O2 sensor? Thank You very much for your help.
Old Jan 10, 2012 | 11:53 AM
P0420 typically means a bad converter. Although off chance it could be a bad sensor.
Given you had the rotten egg smell might be the converter, the smell is a sign of problems.
The P0300 is a code for random misfire on more then one cylinder.
The other codes can be the result of a host of issues beyond the ign system.
As you have no symptoms other then the CEL check out the converter issue first.
Old Oct 23, 2015 | 09:44 AM
Stan Wrzesinski's Avatar
P0300 code on my '98 Camry with 130K miles was caused by bad transformer. The spark was shorting within the transformer probably due to bad insulation inside the transformer.
Over time the temperature cycling destroys the insulation property of potting epoxy.
I replaced the transformer and solved the problem.
Date: 10-20-2015
Saltfish
Oct 26, 2009 06:23 PM
Kevin Karsky Kev
May 6, 2009 09:20 PM
DaveM
Oct 21, 2008 12:42 PM
yngdvr1978
Sep 15, 2008 10:13 AM
tomfrh
Jul 28, 2008 09:34 PM
