Electrical Problem? HELP!
Have a 1998 Camry and have been having some electrical problems.... Any "electronic" item that is suppose to work when the car is off, doesn't! Things like dome light, power door locks, windows when the car is off - before I open the doors.... My aftermarket security system will "arm" but it will not lock the doors. The clock is also changing times. Is this just a fuse issue? I am going nuts!!!
Thanks for the help!
Mike
Mike
It could be a fuse or a broken wire in the wiring harness. certin items are supposed to be supplied with constant power ie. your locks clock etc. the circuit that these items get said power from could be having an issue. Maybe a relay.. Your alarm probably uses a different power source. as most alarms do no get power from these same circuits for obvious security reasons.
pius222
May 3, 2014 02:05 PM
DarkNewEngland
Jul 17, 2011 09:47 AM
dgalla1205
Apr 1, 2011 12:52 AM
