engine lost power
Old Feb 16, 2016 | 08:25 PM
  #21
pesnemesis's Avatar
The engine performs normally when under load when coolant temps are low?
The computer shifts the engine between operational modes at a certain coolant temp.
Did you try operating on the road engine warm with the O2 sensor disconnected and then coolant sensor. O2 sensor is locked out coolant cold.
When cold the computer may not use input from all sensors. If the engine performs normally when under load and coolant cold and has problems coolant hot. It could be a bad sensor.
An engine under load also exposes marginal parts. If compression, etc is OK, these tend to be ign or fuel related. Unless bad fuel a plugged fuel filter is rare on this year/model.
If EGR works, try disconnecting the vacuum hose going the modular, plugging the hose and driving when engine hot.
Suggest trying the above then go through ign system with new parts. This is a hit or miss approach but without a diagnostic machine or code output it tends to come down to an educated guess.
I did try driving with the O2 sensor and coolant sensor disconnected the problem is still there. I tested the egr modulator and it's in working order.
I'm going to replace the temp sensor, it's 5 yrs old and I notice while testing it that I could spin the plug but it doesn't leak. I agree and going to pull and replace sensors.
Thank you for your advise.
Old Feb 21, 2016 | 03:21 PM
  #22
Remember there are several temp sensors. The one with one wire is for the temp gauge.
Old Feb 23, 2016 | 09:25 AM
  #23
pesnemesis's Avatar
Yes, I'm replacing the one on the left(green color) that signals the computer.
Thanks!
Old Feb 25, 2016 | 10:18 AM
  #24
Great!
Old Mar 2, 2016 | 08:06 AM
  #25
pesnemesis's Avatar
The Camry is fixed, it was the spark plug wires, they were not that old but went bad.
Thanks to all for your help it was a tough one to figure out but simple repair.
Old Mar 2, 2016 | 10:38 AM
  #26
Good job in finding the cause.
Thanks for posting back with the fix.
m.hudson
Nov 25, 2011 08:13 AM
sontakke
Sep 4, 2007 05:27 AM
jpease99
Jun 30, 2007 12:38 AM
twinpack
Jun 9, 2007 06:52 AM
JBCAMRY07
May 29, 2006 01:35 AM
