engine swap
Old Jan 29, 2014 | 12:52 AM
98_khriz's Avatar
Post engine swap
Hi I'm new here and I just needed some advice. I have 1998 Toyota Camry le and I've been planning to do a engine swap. I wanted to know what would be the best engine to drop in my camry. I want it to be faster so performance wise what would be the best engine?
Old Jan 29, 2014 | 12:00 PM
1998 Camry offered only two engines options, 4 and 6 cylinder (1MZ-FE).
If the car has the 4 cylinder the best route is to swap for the 6 cylinder. However from a cost standpoint the cheapest route is sell this car and buy another with 6 cylinder.
Changing engines even if offered as an option is expensive. Will need a different trans, axles, computer, wiring harness, front springs, radiator and more.
If wanting to still proceed best to buy a salvaged parts car of the exact same year having the engine you want and swap parts side by side.
If you have the 4 cylinder is may be possible to add a turbo, but the engine was not designed for performance.
Any other engine besides those offered as an option is going to cause LOTS of problems and more expense.
Old Jan 30, 2014 | 12:16 AM
I agree a lot with Toyo. I would go turbo but you should be ready to spend some cash in any of these scenarios. With enough time and money, you can do anything you want.
Old Mar 24, 2015 | 08:10 PM
YamatoXAssassin's Avatar
Inline 6 1JZ or 2JZ SWAP Camry would be cool.
upjeeper
Oct 25, 2012 01:56 PM
carlos1787
May 23, 2009 05:57 AM
scotbot
Sep 12, 2006 09:31 PM
Serenityvalley
May 15, 2006 06:03 PM
