Engine Thribbing
Old Apr 30, 2007 | 08:26 PM
starbase47's Avatar
Default Engine Thribbing
Hello,
I have a 97' Camry LE 4 cyl (117 K Mi), and sometimes when I come to a stop the engine idles ruff. The RPM gage does not stay even at 600 or so. It moves up and down. I read through the board and saw a post about cleaning the throttle body so I did. I also replaced the plugs, wires and PCV valve too. The engine is smother now, but sometimes it slips back to the rough idle from time to time.
Am I missing anything? Any imput you could provide will be greatly appreciated!
Thanks!
Old May 1, 2007 | 04:00 AM
nodrogkam's Avatar
Default RE: Engine Thribbing
loose/damaged vacuum hoses.
Old May 1, 2007 | 10:36 AM
colortv's Avatar
It sounds like your transmission shifts back to lower gear atcertain speed and go back to normal again frequently.
You should check your transmission oil level first.
96camman
Jan 16, 2011 04:32 PM
ggcc
Apr 27, 2007 05:15 PM
