finding out engine year and transmission swap
Hi
I was wondering if there was a way to find out the year of the engine of a camry I was also wondering if the 92 and 94 camry transmission 4 cylinder can be swapped
if both camrys are wide body and both 4 cyl
was built within these years a XV10 (1991–1996)
the manual gearbox should be the same
automatic is a .1992-2001: 5SFE model S51...
Hi thank you for the reply'
I hear around that they are the same but the problem as well is that for some reason when I check on autozone.com the two cars transmission has different part numbers so its strange to have that if they use the exact same transmission
Because of the volume of vehicles and parts toyota handle day to day by computer
they use the vehicles Vin number always then year of build in all part identifications
then go to a visual check of the part required
1992-2001 ... thats 9 years of possible superseded or changed parts ....... some numbers will change for the same part
in this case you are two years apart ......so its the same transmission
SymtecX
02-27-2006 03:16 AM
