fuel door
Old May 4, 2008 | 10:27 PM
melwalz's Avatar
Default fuel door
Help, the latch won't open the fuel door on a 97 camry.The latch is inside by the trunk latch. How do I get it opened?????
thanks
m
Old May 5, 2008 | 12:27 AM
Octapulse's Avatar
Default RE: fuel door
That just happened to me a month ago. The spring clips on the fuel door wear out and break and need to be replaced from time to time. To open the fuel door, have someone hold the fuel door lever inside the car up (like you normally would when trying to open it) and while its being help up, stick something through the side of the fuel door to pop it open (I used a coat hanger). Once you get that open (or before you do) go down to kragen and buy a spring clip for it (should be about $5). Its pretty easy to install, just see how the old one is attached and just remove it and attach the new one.
Bam Bam 65
Oct 20, 2013 05:54 PM
KEVAUG
Mar 17, 2012 12:19 AM
richzimme
Aug 12, 2010 05:10 AM
camaropoor
Jul 23, 2010 10:16 AM
bujji
Jan 23, 2008 12:25 PM
