Fuse blowing problem
I have a 94 Camry with the 2.2 4 cyl. motor. About 3 weeks ago the car would not start but turned over real strong. I isolated the problem to the coil and put an ohm meter on it and found it to be out of range from the specs in the Haynes manual and so I replaced it. New one in, car started right up. Drove for two weeks and the wife pulls into the drive, shuts the car off, won't start again. Same symptoms as before (turns over strong, won't start), with the exception that I found the 30amp AM2 fuse to be blown, so I replaced it. New one in, try to start car, blows AM2 fuse again. Have I got a bad coil or is something else happening? Any pointers would be much appreciated.
blong401
03-18-2008 05:17 PM
