Headlights won't turn on at night
Old Jul 9, 2011 | 06:58 PM
egarci10's Avatar
Default Headlights won't turn on at night
Camry 2000 LE 4 cyclinders
The daytime lights work and the bright lights work. But regular driving lights don't work. please help
Old Jul 10, 2011 | 10:53 AM
The low beam daytime running light operation is complex with 4 relays. How good are you at diagnostic work?
Old Jul 11, 2011 | 12:59 PM
egarci10's Avatar
I'm good at following instructions, so your saying its not the bulbs itself but the relays? so i need to test the relays? if yes which tools do I need?
Old Jul 11, 2011 | 03:52 PM
Correct me if I am wrong but don't the daytime running lights (DRL) and low beams both use the same light bulb filament?
Both high and low beams share the same ground wire circuit.
When the DRL's are turned on a resistor is placed into the ground wire circuit via a relay (DRL No 4) and other relays send power to the low beams. The result is a dimmer light bulb.
When low beams are selected relay No 4 routes the ground wire directly to ground and the same relays send power to the low beams.
Are you sure you have high beams and DRL's.
If you have a voltmeter check for voltage at the low beam filament wiring. Determine if there is power when the DRL's are on but none when low beams are selected.
Old Jul 12, 2011 | 12:58 PM
egarci10's Avatar
high beam & daytime light are the same bulb, and low beam is a separate bulb, OK as I took the bulbs for low beams I noticed both bulbs are burned out so its the bulbs silly me not to check the bulbs before i thought the high/low beams were the same bulb on this car thanks for responding
Old Jul 12, 2011 | 06:37 PM
Great!
Old Jul 17, 2011 | 05:10 PM
hotcorner216's Avatar
2007 OEM Camry headlights for sale! Both are in mint condition, i will sell with new low and high beam bulbs! PM for any questions, i live in so cal for local pick up or i can ship! I NEED THEM GONE NOW! MAKE ME AN OFFER!
Patrick
Mar 30, 2018 04:51 PM
djsky717
Dec 28, 2011 09:52 AM
minghe334
Sep 27, 2010 08:23 AM
mail2mz
Mar 8, 2008 12:07 PM
