'09 Camry Brake Light works for Night Time but not when Braking
Old Dec 28, 2011 | 03:41 AM
djsky717's Avatar
Default '09 Camry Brake Light works for Night Time but not when Braking
2009 Camry LE: my rear brake light doesn't work when braking (fully lit), but it works okay for night-time mode (dimly lit).
This problem is affecting just the right side. The left side is okay for both braking (fully lit) and night-time mode (dimly lit).
Troubleshooting: my deduction led me to believe that my bulb is not burnt out and the wiring harness and fuse are okay because the bulb can be lit during night-time mode, just not when braking. I also think that my brake pedal switch is okay because my left-side brake light is fully lit when braking. I can only speculate it's a circuitry/logic board problem of some sort; I'm just not sure where I can locate the problem.
Has anyone experienced this?
I can't find older posts describing this exact problem, hence starting this thread. Apologies if they do exist. Any help is greatly appreciated. Thanks.
Old Dec 28, 2011 | 09:52 AM
Was not aware the brake lights dimmed at night, thought there was only one setting on/off.
If any of the brake lights work the brake switch is working.
You might be mistaking the taillights being turned on. The brake and taillight filaments share a common bulb.
juarez1980
Nov 22, 2017 08:18 PM
sonamu
Nov 30, 2011 09:19 AM
kiron
Jun 26, 2011 09:45 PM
Huo Yuanjia
Mar 16, 2011 03:14 AM
mail2mz
Mar 8, 2008 12:07 PM
