Heating issue
Old Feb 4, 2025 | 02:04 PM
MeandSamson1's Avatar
Default Heating issue
No heat. Changed thermostat. Gauge will occasionally go hot hot yet still no heat. Water pump? No leaks. I foolishly snipped ABS wires and nothing on my dash liked that
thoughts
Old Feb 4, 2025 | 02:05 PM
Sorry 010 camry 4 cylinder
Old Feb 4, 2025 | 08:34 PM
SEEMS like just low on fluid but geesus where did a gallon of fluid go
Old Feb 5, 2025 | 10:08 AM
Are you stating the low coolant caused the heating issue?
The radiator has plastic upper and lower tanks which can crack over time and leak.
Run your fingers along all coolant hoses large or small to feel for coolant.
Bad radiator cap?
Any coolant accumulating on the carpet under the inside cabin heater core due to leakage?
Cracked overflow tank or hose to tank?
Old Feb 5, 2025 | 05:13 PM
Thanks a million. When it gets warmer I'm gonna put 15psi to it and see if i can see anything
herestoya
Nov 12, 2023 05:19 PM
Camrydude28
Oct 9, 2022 11:38 PM
urbs00007
Jul 10, 2016 05:44 AM
bmfyzf607
Feb 15, 2009 12:23 PM
brad01
Jan 23, 2007 06:35 PM
