My son lost the only key we had to a 98 Camry. I don't know if it had a transponder or just a fob built into it. Can someone tell me if I am going to need a transponder key programmed or can a locksmith just cut me a regular key that will work in the ignition? It has a security system with a red button on the dash. It looked exactly like this one.
Camry started putting chips into keys in 1998. If you have the master key you can make another key using it. If you lost all the keys the cars computer will need to be reflashed.
One can get a key that looks just like the one in the photo and the key can be cut using another key as a pattern. Unless that new key is programmed into the cars computer the engine will not start.
