Replacement key
Old Oct 21, 2016 | 07:32 AM
islanddean's Avatar
Default Replacement key
I recently purchased my first ever Toyota so please excuse this remedial question. I bought a 2001 Camry but theres only 1 key. I need a second key and see i can purchase replacement transponder keys on Ebay and was hoping someone can tell me if those will work.
Alos...if i buy a key off ebay will a locksmith be able to cut the key from the key i have? Thanks again.
Old Oct 21, 2016 | 10:31 PM
Is this a master key or valet key?
A locksmith can cut the key. However the transponder will need to be programmed to the ECU. If not programmed the engine will not start.
Old Jan 11, 2020 | 08:43 AM
AnthonyMartin's Avatar
It was the master key and it can't get cut by a car locksmith, so for that consider visiting the dealership.
Old Jan 11, 2020 | 11:05 AM
Widen your search to those locksmiths who have the equipment and skills to do the job. Your local locksmiths may not.
If you can get the key cut you should be able to program it yourself.
Otherwise call a Toyota dealer and ask if they can make another key based on the cars VIN. Make sure you tell them you have the master key. The key may not be cheap.
After getting the key put it in a safe place. Replacing a lost master key is more trouble and expensive.
Old Mar 7, 2020 | 10:50 AM
MadisonJessica's Avatar
I agree whether you go for a locksmith or dealer, key isn't available at cheap.
Old Mar 10, 2020 | 08:58 AM
Scruffy j dog's Avatar
Had one master key as well, had 3 ordinary keys cut just in case of locking myself out. I would not use them without the master-key in place, then again, it would be fun to test things out "famous last words".
Old Apr 14, 2020 | 07:17 AM
PeterHandscope's Avatar
What output you have got after testing it during lockout and have you called any locksmith to rescue you?
Old Jun 4, 2020 | 07:19 PM
elvis1977's Avatar
Home Depot will cut you one for 5 bucks. I did it last weekend
H1VOLTAG3
Jul 19, 2021 12:50 PM
rajalot
Jul 9, 2020 10:14 AM
Jasperson Alan
Nov 30, 2017 03:56 AM
hoskin14
May 31, 2015 07:19 PM
crazylove
Jul 11, 2012 09:05 PM
