Idle up valve hose routing
Old May 7, 2009 | 06:20 PM
KennyCoe's Avatar
Default Idle up valve hose routing
Where does the Idle up valve air hose route to. I know that it comes off of the valve and attachesto a pipe but where does the hose on the other end go to? I cut it off while pulling the engine and forgot to mark it. Dammit Man!
Kenny
Old May 8, 2009 | 06:33 AM
pedro's Avatar
Assuming I4, assuming IAC valve hoses. Which hose? There are; A/C idle-up, brake booster vac hose and actuator vac hose?
Old May 9, 2009 | 03:01 PM
KennyCoe's Avatar
A/C idle up. A vacuum line comes out from the left end of the plenum it goes into the A/C idle up valve. Another hose comes out of the idle up valve and attaches to a pipe that runs under the intake manifold to another vacuum hose on the right side of the engine. I thought it went to the IAC valve put the size is wrong. So where does it go?
Kenny
Old May 10, 2009 | 07:19 AM
pedro's Avatar
If you have a vacuum routing sticker on your hood, refer to that. The hose from the IAC valve routes to the Idle Up switch (as you know) the other hose from the idle up switch routes to the passenger end of the intake plenum, right on the end of it toward the firewall side. Don't confuse rubber heat shield on hose for hose size.
Old May 10, 2009 | 09:29 PM
KennyCoe's Avatar
Got it thanks
Kamuri
May 8, 2019 04:59 PM
camrycoupe
Sep 3, 2007 12:12 AM
Kamuri
May 24, 2007 03:32 AM
hammsguy2
Sep 1, 2006 05:18 PM
marc780
Apr 10, 2006 06:22 PM
