Indicator light not work
Old Oct 19, 2011 | 07:52 PM
mkv_camry's Avatar
Default Indicator light not work
Hi
i have a 1998 camry 2.2
today, the indicator light went kaput. its not working at all.
i push the stalk up or down but no action. the arrow inside doesn't blink and indicators don't work.
my car starts fine, headlights are ok. so i guess battery should be ok.
what could be other problem?
thanks
Old Oct 19, 2011 | 08:10 PM
Try the hazard lights. If nothing could be the turn signal flasher.
Location is behind the drivers side kick panel.
Old Oct 20, 2011 | 10:34 AM
mkv_camry's Avatar
Hazard lights are working good.
is the location on the left side of steering where coin holder is?
what should i replace if this problem is there. do i replace flasher?
thanks
Old Oct 27, 2011 | 06:15 PM
mkv_camry's Avatar
just thought of updating for others.
it was a small indicator part located in hood that needed replacement. its good now. didn't cost me anything. it was not fuse but something else. i will take pic of the part and post here.
Old Oct 28, 2011 | 10:27 AM
flamechasere1's Avatar
I'm having that same problem. Is the part you're talking about in the fuse box under the hood? I have a replacement turn stalk I was going to put in. I didn't see anything pertaining to turns signals in the fuse box. Thanks!
Old Oct 30, 2011 | 06:47 PM
mkv_camry's Avatar
hi flamechaser. sorry you having the same problem.
i didn't wrote clearly. Here is what happened.
The guy replaced fuse from the driver's side kick panel. he only checked under the hood for voltage whether the battery was in good condition and everything else is working good.
so its not under the hood, the fuse box is on the left side of steering where there is a small compartment to store receipts/loose change. just replace the fuse in there and it will work.
the reason it happened was, my right side signal lamp broke and to protect against morning dew, i tied both ends of wire together thereby causing failure of fuse.
hope this helps
jfirusta
Oct 5, 2011 04:41 PM
baboonia
Dec 29, 2008 08:42 AM
TrueRollers
Apr 30, 2007 03:48 AM
veilmk5
Apr 7, 2006 02:50 AM
