Low Engine Temperature reading 1995 Camry
Old Nov 16, 2008 | 07:54 PM
wongleetoy's Avatar
Default Low Engine Temperature reading 1995 Camry
My 1995 Camry Engine Temp Gauge never gets to the middle of the scale even on extremely hot days with the Air on. The car runs fine and I replaced the Coolant Temp sensor with the same results. The Aux fan comes only only when the Air is on and goes off when the Air is not on. My next change would be the thermostat... Any other suggestions?
Thanks!
Lee..
Old Nov 17, 2008 | 06:08 AM
pedro's Avatar
Default RE: Low Engine Temperature reading 1995 Camry
Test gauge by disconnecting the sender wire and grounding it when the ignition is on (car not running), if gauge goes to hot then gauge is ok. Are you sure you replaced the right sensor? Engine Coolant Temp Sensor is not the gauge sender. Gauge sender has one wire, ECT has two wires. How's your gas mileage? If engine is not enough the mileage will be lower. If all this checks out then replace the thermostat.
Old Nov 17, 2008 | 10:54 PM
wongleetoy's Avatar
I changed the water temp sensor (The one on the thermostat housing) which has two wires going to it. Interesting you mentioned the mileage.. The mileage is crappy around 17 - 20 MPG. I'll try what you mentioned with the one wire. Thanks.
Old Nov 26, 2008 | 07:04 PM
wongleetoy's Avatar
Fixed! Thanks for the suggestion. I had 3 Carmys prior to this but I have never gotten a failed temp gauage sensor.
marklee57
Feb 11, 2014 10:00 AM
Dhomsey
Sep 25, 2013 09:35 AM
XpPaul
Oct 4, 2012 10:52 AM
Rosettiski
Sep 18, 2012 06:55 AM
highalti2d
Mar 9, 2009 07:27 PM
