97 Camry Speedometer Reading Very Low
Old Mar 5, 2009 | 09:37 PM
highalti2d's Avatar
Default 97 Camry Speedometer Reading Very Low
Hello,
I have a 97 Camry that has a speedometer issue. I have to reach about 25MPH before it will read. At 65 MPH it will read about 45-50MPH. It doesn't jump around erratically or anything unusual. I removed the speed sensor and the plastic gear looks okay. Stock wheels and tires. No check engine light.
Any advice would be appreciated.
Thanks,
Jason
Old Mar 6, 2009 | 11:47 AM
If automatic trans does it shift OK. Are the shift times (car MPH) higher or lower then normal?
Old Mar 7, 2009 | 11:37 AM
highalti2d's Avatar
The automatic transmission seems to shift at normal points. It's actually smoother than my 07 camry when it comes to shifting gears. Also I measured the odometer to a 1 mile marker on the side of the road and it appears to be accurate.
Old Mar 9, 2009 | 07:27 PM
stfuad's Avatar
Probably check the wiring on that sensor. Make sure it isn't partially broken/burned/etc...
krivraq
Mar 5, 2014 08:30 PM
marklee57
Feb 11, 2014 10:00 AM
vstadegt
Jan 20, 2011 12:54 AM
ulremember
Dec 5, 2010 01:09 PM
wongleetoy
Nov 26, 2008 07:04 PM
