Old Aug 26, 2015, 03:53 PM
How-Tos on this Topic
Browse all: Exterior
Print Wikipost
Metal squeak noise from a rear wheel.
Old Jul 22, 2010 | 11:54 AM
applepomme's Avatar
Default Metal squeak noise from a rear wheel.
(0) Camry 3.0 2005
(1) only when driving slow, disappears driving fast;
(2) disappears when brake applied;
(3) only after driving awhile, especially after brake;
(4) after pads and rotors were changed, still making noise;
(5) never had this for all my cars in >20 years, only this Camry
Thanks for advice.
Old Jul 22, 2010 | 08:12 PM
blackey777's Avatar
there could be an anti rattle clip rubbing. or a bent backing plate.
Old Aug 9, 2010 | 09:53 AM
applepomme's Avatar
I checked it with the tire off. It doesn't look the anti rattle clip. I wonder if it the calliper piston that doesn't return back and the break pad touched the rotor lossly and made the noise.
The reason I guess this is because this wheel is much hotter than others after it had the noise.
Thanks.
Old Aug 9, 2010 | 12:47 PM
Could be a warped brake drum.
Old Aug 9, 2010 | 04:07 PM
applepomme's Avatar
For the rear brake, the "brake drum" is itself the "rotor", right?
Old Aug 9, 2010 | 06:44 PM
Ops, disregard previous post!
What happens to the noise if you apply the parking brake when moving? If it makes a difference check the drum portion of the rear rotor that is used for the emergency brake.
It is possible for the piston to have retraction issues. As the pads wear the piston moves further out in the caliper. When new pads are installed the piston is now pushed back into the hole. The piston or hole could have some corrosion causing binding.
Check the slider pins on the caliper, this allows the caliper to float with the rotor. The pins may need cleaning and lubing with a lithium grease.
Old Aug 11, 2010 | 11:43 AM
applepomme's Avatar
Hi, Toyomoho: Thanks for the great advice.
I used the parking brake and it makes no difference. I think you're right, the noise is probably from the pad that touches the rotor due to the corrosive piston or slider pins. I googled the web and found the way of greasing the pins. If the piston had corrosion, it may be more difficult to fix.
By the way, I have a novice question: what is the mechanism to pull the brake pads back away from the rotor when the brake is released? I looked 100s images on the web, and didn't notice any spring or similar things on the caliper.
Old Aug 11, 2010 | 09:56 PM
I don't think there is any mechanic device that pulls the pads away from the rotors. When the hydraulic pressure on the piston is released the piston should back off slightly, there is always some drag of the pads on the rotors but not enough to cause problem.
If one caliper is much hotter then the other the piston may not be retracting or the slider pins are binding.
Try rotating the tire by hand, compare one side with the other for noise and drag. Remove the tire and rotate the hub by hand and determine if there is a difference.
Old Mar 1, 2011 | 08:04 AM
krazysick614's Avatar
i'm also havin the same problem with it for the past of couple months also. 93 lxe v6 rotor for my passenger rear. i havan't been around to check the break since it's still new on it. but could it also be an hot spot on the rotor?
yardape52
Jul 4, 2011 10:58 AM
lifeisadimension
Feb 1, 2011 07:33 PM
vocominc@csranet.com
Oct 28, 2008 08:34 PM
kr120505
Dec 26, 2007 11:26 PM
thecamryman
Jul 11, 2007 08:57 PM
