Old Aug 27, 2015, 12:36 PM
How-Tos on this Topic
Browse all: Electrical System
Print Wikipost
O2 sensor -vs- air/fuel ratio sensor
Old Sep 25, 2013 | 08:49 PM
  #31
theduck's Avatar
Default o2 sensor
Joey,say I read the artical.But it refers to the sensor close to the fire wall,is this 6 cyl,he is refering to?Cuz my AFR sensor I see is in the radiator side.Please advise.And really thank you for your time and help.
Old Sep 26, 2013 | 12:01 PM
  #32
Good catch. Should be same diagnostic procedures for the individual sensors for either 4 or 6 cylinder. The V6 will have more sensors.
The code is stating the sensor heater circuit is not working based on the amount of current draw or lack of. The heater works like a soldering iron works or small heating element. The computer monitors the current to the heater. Too much amps indicates a short in the sensor wiring or heating element, too little or zero indicates a broken circuit or burned out element.
The sensor heater element resistance can be checked with an ohm meter.
The computer cycles the power to the heating element. Checking the power at the computer indicates if the computer is working.
If the power cycling and voltage at the sensor is working as specified the computer is also working OK. If not then power should be checked at the computer to determine if the wiring is bad.
Computer failure happens but more often it is sensor problem still requires a 3 year/36K warranty on them thus failure at this time is uncommon.
Old Dec 2, 2013 | 09:56 PM
  #33
theduck's Avatar
Default Air/Fuel Sensor
Hello.can anyone,tell me if a air/fuel sensor DENSO PART #234-9024($150.00 VS$60.00) is the same as DENSO PART #234-9008 are interchangable?They're both air/fuel sensors,THEY'RE NOT O2 SENSORS. I do know they're used on toyota's,but different size engines,a 2.2 vs a 2.5.I have tried to look up the spec's on DENSO'S web site but no luck.The connectors are the same.I checked.I am trying to save some $$$here.I think they will but want a second opinion.thx
Old Dec 3, 2013 | 03:33 PM
  #34
Debunker's Avatar
Default O2 sensor -vs- air/fuel ratio sensor
Hi,
with just a quick look at the connectors (up close).......
I would venture to say no. I hear you with trying to
save what you can, so you can spend only where
you really NEED to though!!
I would just try and Google the Denso part numbers
a bit, see if any of the online car part sites can help
get that price down a few more $$$.
Good Luck!!!!
Sincerely, Bob.
Old Dec 4, 2013 | 12:42 PM
  #35
Try looking up the part number at Rockauto.
Old Dec 5, 2013 | 09:26 AM
  #36
Dhomsey's Avatar
here is a 4 page list and prices of different brands you are looking for 1997-1999 Toyota Camry Air Fuel Ratio Sensor | Partsgeek.com
Old Dec 5, 2013 | 03:02 PM
  #37
theduck's Avatar
Default Sensor
Hello,and thx for the information.I have bought parts from the Geek.I am trying to cross reference the 234-2009 to the 234-4626.I tried the Denso web site no luck.So if someone out their has used a senor that is designed for another car but can work on other camrys this would be great information.
raiders4u2nv
Feb 25, 2014 12:09 AM
camryjim
Dec 2, 2012 11:29 AM
joe_mn
Oct 30, 2009 10:04 AM
nj55
Oct 20, 2009 07:47 PM
RugerRedhawk
May 8, 2008 11:00 AM
