P0303 & P0300 engine code saying cylinder 3 misfire
Old Dec 21, 2021 | 08:44 AM
  #21
Bluechinchilla's Avatar
Speculate the only a way a converter could cause an issue is if was plugged up. Here a vacuum gauge can check for excessive exhaust back pressure. Read up on checking exhaust system back pressure.
Any other codes showing up such as P0171 or P0172? How does the engine run and idle? Has the MPG gone down? Any gas smell in exhaust?
Below is the list of possible issues.
Open/short in wiring or connector issue.
Vacuum hose leaks.
Ignition. Do a spark test and compare to another cylinder If you can swap coils with cylinders try this and determine if the code moves.
Injector.
Fuel pressure. This needs to be done by attaching a pressure gauge.
MAF. Try cleaning the MAF
Engine Coolant Temperature sensor (ECT). Temp between 167 and 212F
Compression.
Valve clearance or timing
PCV valve, hose and connections. Check this first.
Intake air leaks
Also check for exhaust leaks. Check the flex pipe on the exhaust for leaks..
ECM
A decent scanner can check real time coolant temp and MAF readings. Some can read how each cylinder is operating..
No other codes. Just P0303. Checked pressure in the cylinder and it was dead on. Can smell gas. Also I can watch the gas needle go down as driving. Seems to lose power when the heat is turned on. So much so it almost dies at idle.
Old Dec 21, 2021 | 01:33 PM
  #22
Check for a plugged converter which will increase back pressure. A vacuum gauge can do.
Could be low fuel pressure. Some auto parts stores rent a pressure gauge test set to check pressure.
Bberls
Oct 26, 2019 08:21 PM
PsXtreme
May 17, 2018 11:51 AM
jtr
Apr 24, 2018 01:00 PM
sconley
Mar 2, 2012 09:33 AM
Alabama Mikey
Oct 7, 2009 09:23 AM
