P1135 2000 4 cyl
Old Nov 8, 2009 | 12:30 PM
CrazyCJJ3's Avatar
Default P1135 2000 4 cyl
CEL is on. Scanned code came back with P 1135. Can i get a little help on this? From some little research i see this is a Bank 1 Sensor 1 O2 sensor.
Does anyone know what I need to do to fix this (whats parts ill need to purchase specifically and approximate cost). Thanks in advance for anyones time.
Old Nov 10, 2009 | 10:40 PM
Joel_CA's Avatar
Looks like you have a problem with the heater circuit at your air/fuel ratio sensor. This is a fairly common issue- that in most cases is cause by a failed heater within the sensor itself. If you decide to change the sensor on your own- be sure to buy the part from the dealership. Your car needs an air/fuel ratio sensor- NOT AN 02 sensor. They look the same but work differently and are NOT INTERCHANGEABLE.
JJ
ToddS
Nov 11, 2019 12:56 PM
Tatkins85
Jan 19, 2013 08:16 PM
ToddS
Mar 26, 2012 07:22 PM
kjcho92
Mar 5, 2008 12:32 PM
flyboi
Aug 15, 2007 02:17 PM
