Please someone help me this is driving me crazy!!!
Old Jun 10, 2009 | 02:07 PM
omgmycamrydoesntwork's Avatar
Default Please someone help me this is driving me crazy!!!
92 camry stalling/idle sometimes around 2000
So this is what happen...car started stalling while coming to a stop or at idle...then a few weeks later the car was completely dead...new distributor and now it starts...
This is what i did to the car so far but still have no luck!!!!
distributor
coil
distributor cap and rotor
spark plugs
spark plug wires
coolant temp sensors(all 3 senors)
fuel regulator
fuel filter
waterpump
timing belt(had timing checked 3 times..everything was fine)
Check engine light was on for knock sensor...Changed knock sensor nomore light...
cleaned egr system(wasnt clogged up but still cleaned it)
cleaned idle control valve
changed tps from a working car(made no difference)
PLEASE SOMEONE HELP ME THIS IS DRIVING ME CRAZY!!!
Old Jun 14, 2009 | 07:25 AM
pedro's Avatar
Have you checked fuel pressure when this happens? After stall does car re-start and run ok? Water in fuel?? Changed gas stations?
Old Jun 18, 2009 | 09:06 AM
I will have to check fuel pressure this week...after it stalls it does restart and will continue to stall out...I cant even drive the car up the street without it dying like 5 times
Old Jun 20, 2009 | 02:40 PM
T.K.'s Avatar
Hi, I don't know if this is it, but I told my mechanic about a similar problem with my '98 Camry LE. Occasionally when I start it in the morning, there is no idle (just dies). I have to hold my foot on the gas just to back it out of the garage. It corrects itself while driving, but sometimes the idle races. The next day/week, will be fine but then it happens again one morning.
My mechanic said it is a common problem here in California (something to do with the California gasoline not being compatible with Camrys). Said it was some kind of gas regulator that needed to be replaced to adapt with the California regulations (unless I heard him wrong). He said he hears of this problem often, and that the part costs about $320.00 + labor. I can wait for awhile as the problem hasn't gotten bad enough yet to replace.
This might be your problem as well. Good luck!
Old Jun 20, 2009 | 08:11 PM
sevenltr's Avatar
This sounds like a vacuum leak to me. Check to see that all of the vacuum lines are connected and are not cracked or broken. You pulled the EGR valve, did you check the operation of the EGR valve with a vacuum pump? Did you make sure that the EGR valve closes all the way? Did you reinstall with a new gasket and tighten it down? You could check for a vacuum leak with a can of starting fluid, spray it on the intake runners where the intake bolts to the head and other likely places for vacuum leak, if RPM goes up, you found your leak. I hope this helps, good luck.
Dave
sundarpn
Sep 21, 2024 08:50 AM
V6 5spdSTEF
Nov 1, 2012 04:22 AM
cgv0635
May 12, 2012 09:11 AM
Specvern
May 17, 2011 08:58 AM
