Putting a '91 camry transmission in an '87 camry
Old Aug 25, 2008 | 05:54 PM
tontagator's Avatar
Default Putting a '91 camry transmission in an '87 camry
So my transmission went out in my '87 camry 3 days after graduation(just my luck) anyways my friend told me that the years 87-91 camrys are the same generation so it wouldn't matter if i got a tranny from any of those years... is that true?
Old Aug 26, 2008 | 05:14 AM
andry's Avatar
Default RE: Putting a '91 camry transmission in an '87 camry
if the same generation it will be fit. but better use transmission parts for 87 camry, this way only for alternative if you can not find transmission for your 87 camry.
anyway welcome to the forum.
Old Aug 27, 2008 | 11:34 PM
Check the drivers door for a sticker and trans type, something like A140E or A140L. The E is electronic controlled by the cars computer, the L is hydraulic controlled (does not require a computer).
Old Sep 2, 2008 | 07:21 PM
drewtiss's Avatar
Andry is right. I also think that they share the same generation. Eventually they will fit in your '87 camry but that doesn't mean that it will work perfectly for that '87 camry for it was really meant for a '91 etc.
__________________________________________________
Powered by Autopartswarehouse.com
Old Sep 3, 2008 | 08:32 AM
lavalleemike's Avatar
As long as it is the same motor it will be the same tranny.
94Owner
Jun 12, 2012 03:08 PM
RobtLee
May 5, 2012 03:41 PM
Camryms38801
Jan 23, 2012 06:55 PM
Chriscam84
Dec 31, 2008 04:56 PM
