Replace Heater hose. 97 Camry
Old Sep 26, 2010 | 05:02 PM
CaliPirate's Avatar
Default Replace Heater hose. 97 Camry
I have a 97 Camry 4cyl and my heater hose has a hole. I'm trying to replace but cant seem to remove the hose from the firewall. can anyone help me out?
Old Sep 26, 2010 | 06:47 PM
This is one of the hoses going to the heater core? You removed the clamp?
The hose connects to a pipe that connects to the heater core.
The underlying tube is pretty thin. Don't be too aggressive with pliers or you can crush or twist the tube.
Try taking a sharp blade such box cutter, gently cut length wise along the hose. Split the hose down to the pipe. The pipe may be made of a soft material thus try not to scratch the pipe when cutting.
One split, try gently twisting the hose. Might work liquid hand soap into the hose/pipe joint first.
The hose will break free eventually, take your time, be gently.
KEVAUG
Jun 11, 2014 10:35 PM
CaliPirate
Sep 26, 2010 04:59 PM
armedandsafe
Dec 9, 2008 07:56 PM
drickelton
Jul 11, 2008 10:13 PM
GntlBen
Mar 11, 2007 11:39 PM
