Reverse & tail light wont work???
Old Apr 22, 2007 | 08:06 PM
99toycamry's Avatar
Default Reverse & tail light wont work???
HI i own a 99 camry le auto and recently the reverse and tail light on my trunk wont work. i check the fuse and replaced the bulb and it still wont work. The only light that work on my trunk is the two above the license plate. Any help please.
thanks
Old Apr 23, 2007 | 03:50 AM
toyoboy's Avatar
Default RE: Reverse & tail light wont work???
check the wireharness for the trunk light.. its located beside the left trunk hinge..it time thewires flex so much that they break apart...
Old Apr 24, 2007 | 04:46 AM
EagerBeaver's Avatar
Yeah, the wires usually break at he trunk hinge inside the wire conduit. Untape and do a good visual.
Old Apr 24, 2007 | 03:58 PM
99toycamry's Avatar
thank you for the replies
do you guys have any pic of the wire that needs to be checked??
thanks
Old Apr 24, 2007 | 04:14 PM
kwtrading's Avatar
i had a similar problem with my 98
there was a short somewhere in the tail lights/license plate that would blow the fuse instantlyand i just could not identify it.
i ended up rewiring all the way back to the tail and manually splicing everything (major pain) to get them back up and running best as possible.
good luck.
Old Apr 24, 2007 | 05:54 PM
toyoboy's Avatar
i would get a repair manual to find out which wires you need to find....if you don't get a manual. just look at the colored wires behind the light socket and use that as a color referance..and while you're in the wire harness repairing the broken wires give the other wires a good pull to sure that they're not in the proccess of breaking....
Old Apr 25, 2007 | 01:43 PM
99toycamry's Avatar
Where is the fuse to the tail lights located???
thanks
Old Apr 26, 2007 | 04:39 AM
toyoboy's Avatar
i think its on the drivers kick panel...if not check under the hood...
Cindyv11
Jan 6, 2018 01:10 PM
ac2011
Jul 24, 2011 09:19 PM
artnsf
May 24, 2011 01:01 PM
Linds94cam
Oct 5, 2005 04:48 PM
