Sponsored by:
Sponsored by:
Seat Belt Chime on/off
Old 11-13-2018, 09:41 AM
cmk033's Avatar
Default Seat Belt Chime on/off
There is procedures you can go through to disable the seat belt chime on all Toyota vehicle. The procedure is as follows:
Look for a tiny **** on the instrument panel and press it to toggle between the odometer reading and the trip odometer reading. Keep pressing the **** until you see "ODO." Turn off the vehicle.Turn the ignition on but don't crank the engine. Pull the tiny **** out for 10 seconds. While still holding the **** out, put on your seat belt and keep holding the **** for another 5 seconds then release it. The instrument panel will now read "B off."Repeat the above procedure to turn the seat belt warning chime back on.
I have 2013 Camry and the procedure does not work. The reason the procedure does not work is because there is the step similar to seat belt chime off for Eco Light on/off feature.
Does anyone know how to turn off the seat belt chime for 2013 Camry?
Old 06-01-2022, 04:35 PM
Xspurt's Avatar
2022 LE here, looking for the same info. Does anyone know how to disable the alarm?
Old 06-01-2022, 09:39 PM
I think your best bet is to go on eBay and buy one of those dummy clips that clip in to the buckle.
I'm pretty sure the DOT wouldn't allow a car to not have that annoying chime/bell to remind you to buckle up.
Old 09-11-2022, 11:07 PM
thor91009's Avatar
Default Did you figure it out!
I have a 2012 with the same issue with the seat belt chime disable not working due to eco mode and was wondering if you found out how to disable it without buying extra parts?
Old 09-12-2022, 10:45 AM
cmk033's Avatar
This feature has been disabled for newer Camry (2012? ~)as it is illegal to disable feature, I've learned.
Warning chime is annoying but it is a safety feature to remind you of the fact you do not have a seatbelt on. So I would live with it by wearing seat belts.
Hippo393
12-25-2020 07:27 AM
mark garrett
12-12-2016 10:04 AM
nkm9222
07-04-2014 12:36 AM
nursecamry
04-21-2007 11:13 PM
DirtWind
11-25-2006 10:41 PM
Quick Reply: Seat Belt Chime on/off
