Old Aug 26, 2015, 03:53 PM
How-Tos on this Topic
Browse all: Exterior
Print Wikipost
squeaky back doors
Old Aug 23, 2008 | 04:38 PM
mjnrite1's Avatar
Default squeaky back doors
when i go to open or close the back doors of my 94 camry, they squeak loudly. i have tried ilicon spray onthe doors moving parts. car smells like lubricant and the doors still squeak.
any solutions or thoughts?
Old Aug 23, 2008 | 05:43 PM
93camryxle's Avatar
Default RE: squeaky back doors
Typically white lithium grease is used on hinges (which is where the squeeking is coming from). I don't thinkit really smells at all and it lasts a long time. You should probabley clean the silicon off first to make sure the lithium really gets into the hinge
Old Aug 24, 2008 | 09:47 AM
andry's Avatar
i've ever faced the same problem. i used WD-40 and it is good now.
Old Aug 25, 2008 | 11:03 AM
diver1972's Avatar
ORIGINAL: mjnrite1
Do you know exactly where the squeaking is coming from? Specifically, could it be coming from the black weatherstripping (e.g. a part of the door frame rubs against a part of the weatherstripping)?
On my car, a '98 Camry, both the front driver and front passenger doors squeak just immediately before closingand immediatelyupon opening...they do not squeak at any other point in the range of motion of the door. I isolated it toa 1/2" portion of thedoor frame rubbing directly against part of the weatherstripping.
Solution: apply a silicone-based rubber/vinyl/plastic conditioner to the weatherstripping. Ineed to re-treat this area about three times per year to silence the squeak sincethe conditionereither gets absorbed by the rubber or just runs/wears off over the course of several months.
Old Aug 25, 2008 | 11:08 AM
diver1972's Avatar
ORIGINAL: 93camryxle
[sm=signs007.gif]
Old Aug 25, 2008 | 11:22 AM
diver1972's Avatar
To follow-up on my previous post,this isthe product that I happen to be using this year.
http://www.blackmagicshine.com/produ...ine-protectant
I have also had good results from Meguiar's products as well.
I have no interest, financial or otherwise, in promoting either of these two companies' products.
whyandwhat4
May 8, 2014 09:44 AM
plsntnrules
Oct 24, 2008 04:55 PM
cm11402008
Sep 16, 2008 10:28 AM
camry_guy
Jun 11, 2007 05:40 PM
CKSAMartin
May 22, 2006 04:33 PM
