Toyota Camry 1998 CSi :: Back Doors Not Opening from inside ::
Old Apr 11, 2011 | 09:22 AM
whyandwhat4's Avatar
Question Toyota Camry 1998 CSi :: Back Doors Not Opening from inside ::
Hi All,
I have Toyota Camry 1998 with factory fitted auto locks.
All doors Lock and Un-Lock with Remote and inside door button.
When Doors Un-locked, Can't open back doors from inside even though Child lock is "Unlocked as well" but can open the doors from outside.
Please can anyone help me explain the problem and solution.
THANKS GUYS IN ADVANCE.
ALL HELPING GUYS ARE CHAMPS
Old Apr 11, 2011 | 10:24 AM
You can't open any back door at that door? Do the back door locks remain on, then you can't unlock them from the individual back door?
Old Apr 12, 2011 | 03:08 AM
Arrow Door locks
Both back doors can't be opened from inside (when unlocked and door handle is pulled from inside to open the door) even they are unlocked manually.
Old Apr 13, 2011 | 04:21 AM
xpeed's Avatar
Try taking off the door panel and see if any actuators and links are broken. Also check the child lock switch inside and see if that's broken as well. Wish I can be more of a help but i don't have power locks in my camry so I can't really pinpoint the problem for you.
Old Apr 13, 2011 | 09:23 AM
Yes, if you can not manually unlock the doors manually there may be something wrong mechanically with the locking system.
Old Apr 14, 2011 | 04:38 AM
@EVERYONE
Thanks guys I will be removing door panels and see me if I can Find n Fix the problem.
Cheers
Old Apr 14, 2011 | 10:06 PM
The actuators are 12V.
The Blue/Red and Blue/Black wires are for the lock motor.
The Blue/Yellow and White/Black (ground) wires for a built-in switch that tells the door lock system of the lock is on or off based on its position.
Old May 8, 2014 | 05:42 AM
Clad132's Avatar
Default Same problem
Hi, I have exactly the same problem, all linkages seem to be ok, if you find a solution could you please share with me the details?
Old May 8, 2014 | 09:44 AM
Do the rear door inside lock ***** move when triggered to lock/unlocked? And move to the unlock position?
You still can't open the rear door if the rear manual locks are unlocked?
Sometimes the push/pull rods fall off the inside door handle/lock. The handle can be removed to check the rods.
whyandwhat4
May 29, 2011 05:30 AM
speckyboy
Feb 1, 2011 10:38 AM
mjnrite1
Aug 25, 2008 11:22 AM
torrez
May 21, 2007 09:01 AM
cmrylovr
Jul 30, 2006 05:10 PM
