Taillight Out Warning Lamp
Old Feb 17, 2012 | 04:36 PM
broomstic's Avatar
Default Taillight Out Warning Lamp
I have a 2000 Camry CE and whenever I have the headlights on and press the brake pedal I get a tailight out warning lamp on the dash. It only occurs when the headlights are turned on. I have check all the rear taillights and all are functioning fine. What should I do?
Thanks for your help,
Steve
Old Feb 17, 2012 | 09:23 PM
Suggest replacing all tail and brake lights.
When replacing check for corrosion and moisture in the bulb sockets.
The warning system is tied into both tail and stop light systems having lots of dual filament bulbs (combo brake and tail). Sometimes a bulb can look OK but have a problem.
Old Feb 18, 2012 | 03:16 PM
charliemike56's Avatar
Default Tail light out warning light
Set it up for the tail light warning light to come on. Have someone check your license plate illumination light/s. That's what it was on mine.
tylerphelps2
Jul 26, 2012 10:02 PM
Bubbacummis
Aug 1, 2011 02:58 PM
hempsy29
Oct 19, 2010 09:12 PM
CocDiezel
Jan 17, 2010 02:36 PM
camry313
Apr 12, 2007 01:54 PM
