Timing belt tensioner noise
Old Oct 24, 2015 | 06:26 PM
gnx547's Avatar
Default Timing belt tensioner noise
When I bought my 97 Camry V6, there is a noise coming from behind the timing cover. After taking the timing belt off, I found where the noise was coming from. It is the tensioner that is slight rubbing on the back of the mounting tab. When I took off the tensioner and spun it by hand, there is no noise but if I mount it back with the bolt and I spin it, there is rubbing noise. I'm thinking a spacer is missing behind the tensioner? Can anyone confirm with me if there should be a spacer behind the tensioner?
Old Oct 24, 2015 | 10:18 PM
dirty hands's Avatar
by that picture - there was no spacer - you can see a red outline on the inside of that tension-er
in the engine pdf page 40 the other idler pulley its different -- has something behind the bolt and pulley
that black backing plate isnt bolted up in place missing two bolts maybe another ..is that is why its rubbing
go by how the belt lines up with the other cogs
when the timing belt is back on
rotate engine fully twice clockwise by hand .. to check timing marks are spot on
if the belt isnt straight it will run off the pulleys or shread
nice water pump
Old Oct 25, 2015 | 08:18 PM
gnx547's Avatar
Actually the backing plate bolts were there before I took off the belt. The tensioner was bolted with the backing plate bolts on when I spun it by hand and thats when I was hearing the rubbing noise.
Old Oct 25, 2015 | 09:38 PM
your call then ... watch the torque on that bolt
if the bearing sound is still in the tension-er after the washer is fitted the bearing is faulty (too much crush )
to test the theory
you will have to try thin flat washers -- till you clear the backing plate..
end of the day .. the timing belt must be running true
darkfreelife
Jun 18, 2014 12:38 PM
oldad
Jan 7, 2012 07:28 PM
lacruiser
Aug 5, 2009 05:07 PM
johnbrisc
Mar 29, 2009 03:34 PM
dmitchell
Jan 20, 2008 08:22 PM
