tire pressure gauge
Old Mar 6, 2015 | 06:42 PM
EZDriver's Avatar
Smile tire pressure gauge
I have a 2013 Camry LE. Is there a way to deactivate the little icon on the instrument panel that tells you one of the tires is low in pressure. This thing is more trouble than it is worth. All tires are at 32 psi which is as high as I want to go. The orange light is on and won't go out. What do I do?
Please don't tell me to go to the dealer. They are 50 miles away in traffic. I am a DIYer and hope there is a way to kill this light. This has happened several times and is becoming quite annoying.
Thanks guys
Old Mar 6, 2015 | 08:48 PM
No way to deactivate.
If the spare tire has a sensor, check spare tire pressure.
Set all tires to the pressure you want. Then check owners manual for the method to reset the system. Barring other problems the system will then be happy at the pressure you set it at.
Old Mar 6, 2015 | 08:55 PM
Typical TPMS reset is a black button that can be seen when the glove box door is open.
If you know all tires are set at 32 psi, hit the reset button and you should be good to go.
warlar
Sep 12, 2012 09:35 AM
mdw
May 16, 2010 03:07 PM
hi_cyberwarrior
13
Apr 11, 2008 03:41 PM
khanh007
Aug 31, 2006 12:27 AM
aebomb
Jun 7, 2006 11:42 AM
