Toyota Camry 2001
Old Mar 21, 2009 | 01:38 PM
tmassia's Avatar
Question Toyota Camry 2001
I have been experiencing a cracking noise while I'm backing out of my drive way. I do not experience that noise at any other time. Does anyone have an idea of what could be the cause?
Old Mar 22, 2009 | 09:38 PM
From the brakes?
Old Mar 24, 2009 | 04:34 PM
tmassia's Avatar
Thanks for your response, however I put in new rotors and new pads about a month ago, the noise still there. Could the brakes make that noise only while backing out?
Old Mar 24, 2009 | 09:26 PM
4 wheel disk brakes?
The pads would shift in the opposite direction.
Any change in noise when you apply the brakes or a little emergency brake?
Old Mar 25, 2009 | 01:02 PM
tmassia's Avatar
My car has only front brakes, I have drums in the rear. We live in a small hill, so when we are backing out of the driveway we are not applying the brakes, as a matter of fact we need to accelerate a little because the car will be backing up hill, I hope i'm explaining myself well enough so you may understand. It is driving me insane, because it only happens while when I backed the car out of the driveway. Once again, thanks a lot for your response.
Old Mar 25, 2009 | 06:49 PM
It could be the front brake pads shifting backward in the caliper holder.
If a popping noise might be the CV joints. Make some 90 degree turns at slow speeds and listen for popping.
Or rear brake shoes moving around. Apply a little emergency brake as you back up, this will shift the shoes a little. Determine if the noise changes.
virus04
Jul 14, 2008 02:13 PM
monteiro1
Jul 6, 2008 10:24 PM
bballsk8er333
Jan 6, 2008 10:07 PM
boogz
Oct 10, 2007 07:55 PM
