trans fluid drain
Old Feb 25, 2021 | 02:52 PM
mark garrett's Avatar
Cool trans fluid drain
I watched a video of how to drain 2012 camry, only 2 quarts drained, is this right?
Old Feb 25, 2021 | 03:30 PM
There is approximately 2 quarts of fluid in the trans oil pan. The rest of the fluid remains in the torque converter.
Old Feb 25, 2021 | 04:48 PM
the dealer wants 120. to drain, if only 2 quarts that's a little steep, 225. for a flush?
Old Feb 25, 2021 | 05:02 PM
If you have the money, change ALL of the fluid out at once. Dirty and worn out fluid is the main cause of trans failure.
Old Apr 8, 2021 | 09:54 PM
Jyyota's Avatar
Lots of thoughts with this, is the fluid really dirty or burned smelling or even very dark in color ? I have heard that a full fluid change can even introduce problems. A simple drain and change of the filter is very easy if you are a do it yourself type. There are a number of web videos out there that walk you through it. I just did my old 96 Camry V6 and it took about and hour. If you aren't having issues with shifting and so forth and if the fluid looks good on the dipstick then I would only monitor it's level and keep driving. But that's just my 2 cents. Good Luck
Old Apr 28, 2021 | 04:08 PM
man-jo's Avatar
I have recently changed my atf at a service shop , the mechanic drained about 4 litres by just unscrewing the drain plug .I have a camry 2010 hybrid.
Old Apr 29, 2021 | 10:50 AM
Is 4 litres the same as 2 quarts? How much did he charge?
Old Apr 30, 2021 | 03:31 AM
man-jo's Avatar
1 litre = 1.056 quart
I am certain of the volume because he poured the whole of a 4 litres can of atf into the transmission
Old Apr 30, 2021 | 04:24 PM
The hybrid has a different transmission then the all gas powered car.
virginia digger
Sep 19, 2020 05:09 PM
CrystalMath
Jan 27, 2020 03:05 PM
mobile1
Feb 23, 2017 11:28 AM
sandberg
May 4, 2013 01:42 AM
hughfree
Feb 5, 2010 10:28 PM
