Transmission Oil Hose
Old May 3, 2018 | 02:49 AM
tweakit's Avatar
Default Transmission Oil Hose
Can anyone tell me what the ID is for the stock transmission oil cooler hose on my 2014 Camry SE? It eyeballs like 3/8" but the Amazon and Auto Zone are claiming it's 11/32"?
Thanks.
Old May 3, 2018 | 10:52 AM
The 11/32 in comes up as OEM size.
Old May 3, 2018 | 11:34 AM
tweakit's Avatar
1) Thank you. May I ask where you saw that?
2) Also, do you have any experience in putting 11/32" hose on a 3/8 barb or inverted flare? I've heard they are compatible but I'm concerned it may be tough to get on and off.
Old May 4, 2018 | 11:44 AM
1) Have no official Toyota reference on size. Only what numerous after market sources state. Can you remove an oil line and check?
2) The smaller hose should slide onto the larger barb OK. Are you replacing the original lines or?
Old May 4, 2018 | 12:57 PM
tweakit's Avatar
Once i start the work I'll see if the hose shows its size or I'll mic the OD which should tell us. I agree the after market replacements all indicate the 11/32 is the only valid replacement. I've also seen references the 11/32 hose will fit on barbs from 5/16 to 3/8 so it seems you cant go wrong with 11/32. I went ahead and ordered the 11/32 hose. Not sure if i will replace the existing hose or just tap into the return line using a barrel flare mender. I'm installing a cooler soon and doing a complete fluid replace. That's the plan anyway and I'm committed since I've ordered many of the parts.
Take a look at my post here https://www.camryforums.com/forum/ge...filters-52253/ where I ask a few new questions about ATF and in-line filter.
Thanks for reading!
Kamuri
May 8, 2019 04:59 PM
1989_Camry
Jan 2, 2015 12:50 PM
Kamuri
May 24, 2007 03:32 AM
mutoy
May 21, 2007 11:09 PM
hammsguy2
Sep 1, 2006 05:18 PM
