'99 camry w/ INJEN IS SERIES= check engine light?! please help!
hi all,
i installed an injen IS series intake on my '99 camry LE (4cyl) and after driving a while, the check engine light came on. it is my daily driver, and i havent noticed or heard anything weird going on, so i was wondering if this has happened to anyone, or if anyone can please advise?
thanks in advance!
-JON
thanks in advance!
-JON
Usually, when using oiled aftermarket filters (K&n, spectre, etc.) they come with excess oil in the filter and it tends to get sucked in onto the sensor and that sometimes tends to throw codes as the sensors are very sensitive to debris.
Installed the same intake on my '99 CE. Driving on it for a couple months now and I didn't have the check engine light problem. Check to see that your MAF sensor is in tight and is clean on the tip that sits inside the intake.
they come with excess oil in the filter and it tends to get sucked in onto the sensor and that sometimes tends to throw codes as the sensors are very sensitive to debris. Installed the same intake on my '99 CE. Driving on it for a couple months now and I didn't have the check engine light problem.
tooNz626
Jun 16, 2012 09:45 PM
sconley
Mar 2, 2012 09:33 AM
sharpmusic
Dec 2, 2010 03:02 AM
J2Performance
Dec 18, 2007 12:22 PM
