1994 Camry Air Bag Light on Dash
took steering wheel off to fix hi/low beam switch. when put back together the airbag light on the dash stays on. Any suggestions as to why and what I can do. Am an experienced mechanic in running gear, but not this stuff.
Assume you reconnected the wiring correctly to the airbag.
Did you turn on the ign key when the bag wiring was disconnected? If so the air bag computer will note the disconnected plug and set a trouble code. Reconnecting the plug will not reset the computer. This needs to be done manually.
