2002 camry 2.4 engine can only find 1 temperature sensor
Old Mar 15, 2020 | 01:21 PM
Trabectome1's Avatar
Default 2002 camry 2.4 engine can only find 1 temperature sensor
CAN SOMEONE PLEASE HELP !!! i WAS TOLD THAT THERE ARE 2 TEMPERATURE SENSORS 1 3 PIN AND 1 2 PIN. I replaced the 3 pin temperature sensor located next to the oil pressue sensor but can not locate were the other sensor is.
Old Mar 15, 2020 | 02:45 PM
What are the wire colors for the sensor you replaced?
Old Mar 15, 2020 | 02:51 PM
Green & Brown
Old Mar 15, 2020 | 09:41 PM
Could the wire colors be green with a black stripe and brown?
The 4 cylinder has one temp sensor. This sensor ties into the engine computer which then sends signals to the 3 radiator fan relays.
Turn the A/C on and determine which fans cycle on/off with the A/C compressor.
Old Mar 16, 2020 | 07:47 AM
RIGHT NOW ONLY THE DRIVER SIDE FAN COMES ON, ALSO i REPLACED THE FAN RELAYS.
Old Mar 16, 2020 | 12:28 PM
You replaced all 3 relays?
Passengers side fan is A/C fan which is controlled by No 3 fan relay. Fan plug wires should be black/red (goes to relay) and red. The relay power source is the 30A CDS fuse.
Check if the non working fan works by applying 12v to fan wires. Black/red wire is + wire.
Old Mar 17, 2020 | 07:24 AM
Thanks so much !!!! IT WAS FAN RELAY # 3. I only replaced 1 & 2 did not even know there was a 3.
Old Mar 17, 2020 | 05:59 PM
Great job!
jmiles
Jun 22, 2018 12:04 PM
gpa963
Apr 22, 2018 10:49 PM
DKHT
Oct 1, 2017 02:41 PM
ToyCam
Sep 23, 2010 07:56 PM
cranker
Mar 12, 2007 04:01 AM
